I am trying to install JAVA on my Ubuntu 12.04, and I followed the official instructions: http://java.com/en/download/help/linux_x64_install.xml#install
I am stuck at #3: Unpack the tarball and install Java. I have succesfully run tar zxvf jre-7u7-linux-x64.tar.gz (which just unpacks), but what is the command for installing it?
BillyJean
  • 977
Step 1: Open Applicaction>> Accessories>> Terminal
Step 2: Type commandline as below...
  sudo apt-get install openjdk-6-jdk
Step 3: Type commandline as below...
  apt-cache search jdk
Step 4: For "JAVA_HOME" (Environment Variable) type command as shown below, in "Terminal" using your installation path...
  export JAVA_HOME=/usr/lib/jvm/java-6-openjdk
Step 5: For "PATH" (Environment Variable) type command as shown below, in "Terminal" using your installation path...
  export PATH=$PATH:/usr/lib/jvm/java-6-openjdk/bin
Step 6: Check for "open jdk" installation, just type command in "Terminal" as shown below javac then type java-version
