W: Failed to fetch http://ppa.launchpad.net/merlwiz79/cinnamon-ppa/ubuntu/dists/quantal/main/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://ppa.launchpad.net/merlwiz79/cinnamon-ppa/ubuntu/dists/quantal/main/binary-i386/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
ashley@ashley-SVE15113FDW:/etc/apt$ sudo apt-get install cinnamon
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
cinnamon : Depends: cinnamon-common (= 2.0.14-20131203040047-quantal) but 2.0.14-20131203040103-precise is to be installed
Recommends: cinnamon-screensaver but it is not going to be installed
Recommends: gir1.2-cjsdbus-1.0 but it is not installable
Recommends: cinnamon-bluetooth but it is not going to be installed
Asked
Active
Viewed 1,481 times
-1
Registered User
- 9,761
First remove the ppa:merlwiz79/cinnamon-ppa from the list . You can do that by going
Software and Updates -> Other software.
Now add this new ppa by typing :
sudo add-apt-repository ppa:gwendal-lebihan-dev/cinnamon-nightly
Now you can install it using
sudo apt-get update && sudo apt-get install cinnamon
g_p
- 19,034
- 6
- 59
- 69
