I am using Ubuntu 12.04 and I was doing through a terminal tutorial. There was explained about echo command and he mentioned something about adding your name to the sudoers file using echo >>. I am just wondering what it was? Can anyone tell me how to do it?
Asked
Active
Viewed 2.0k times
Radu Rădeanu
- 174,089
- 51
- 332
- 407
Jatttt
- 2,367
- 12
- 33
- 43
Not Recommended:
First login as root using the following command:
sudo -i
Then type:
echo "username ALL=(ALL) ALL" >> /etc/sudoers
Change username with your user name.
It will add the username to sudoers file. But doing this may lock out you from sudo.
Recommended:
If you want to edit your /etc/sudoers use visudo
sudo visudo
You can use /etc/sudoers.d instead of modifying /etc/sudoers.
For more see here.
