This works:
sudo /etc/init.d/apache2 restart
It asks for my password, I enter it and apache restarts.
Then I try this:
cd /etc/init.d
sudo apache2 restart
Nope, it doesn't work. Apache displays usage info. Why can't I navigate to the directory and do the restart.
As must by now be obvious, I'm absolutely a newbie. For what it's worth I'm using Ubuntu 12.04
Emmanuel
  • 101
If you run
the program apache2 is searched in the folders that the environment variable $PATH contains, not in your current working folder. So it doesn't run /etc/init.d/apache2 but /usr/sbin/apache2.
You can use
cd /etc/init.d
sudo ./apache2 restart
Here ./apache2 calls the program apache2 that is in the current working folder so you actually run /etc/init.d/apache2
The correct way to invoke (stop or restart or start) any service, is to give it's full path name as,
OR
sudo service apache2 restart
Avinash Raj
  • 80,446
You can put it simply by typing
by the way, can you give the output when you run this command?
