How do I turn Ubuntu off?
I can't find a button called shut down or turn off.
chesedo
  • 1,749
  • 14
  • 25
Run the below commands on terminal to poweroff,
sudo shutdown -P now
OR
sudo poweroff
OR
Click on the gear icon in the top-right corner and select Shutdown option from the list.
Avinash Raj
  • 80,446
If you're using the default Ubuntu installation (with "Unity"), there should be a gear-like icon in the extreme top-right of your screen... Click this, followed by "Shut down...", then just follow the bouncing ball.
you can use this command "shutdown now".
sriraj
  • 149
