I want to upgrade from ubuntu 12.10 to 13.10 but i had question when upgrading does the data get removed or should we make backup of it or can we install just like that
Direct distribution upgade from Ubuntu 12.10 to 13.10 is not possible.But you can upgrade Ubuntu 12.10 to Ubuntu 13.10 through Ubuntu 13.10 live disk.
Yes your data's will be lost if you don't have a seperate /home partition.
Avinash Raj
  • 80,446
So long as the installer does not go wrong or encounter an issue, you should not lose any data, everything in /home should be untouched. However, you should as a good practice backup your data on a regular basis, and always before a major system change.
willl459
  • 433
