-1
I recently made Ubuntu 12.0.4 bootable through my flashdrive. I've done this before, and have had no problems on previous flashdrives; the only problem I ran into then was I ran out of space, and now I reformatted my flashdrive to give me more space. The program I am trying to install is Wine 1.7, and the instructions given here aren't working for me this time. When I try and install it through terminal, I get this message every time:
Reading package lists... Done
Building dependency tree
 wine1.7 : Depends: wine1.7-amd64 (= 1:1.7.12-0ubuntu1) but it is not going to be installed
           Depends: wine1.7-i386 (= 1:1.7.12-0ubuntu1)
           Recommends: fonts-droid but it is not installable
           Recommends: ttf-mscorefonts-installer but it is not installable
           Recommends: fonts-horai-umefont but it is not installable
           Recommends: winetricks but it is not going to be installed
If anyone knows what this means I'd appreciate it.
try removing wine repo from sources.list, updates sources.list (sudo apt-get update) And if required add the latest repo info into the list and again update the list.
Try installing wine now.
sudo apt-get check does the trick. You might want to use also apt-get autoclean && apt-get autoremove
