I'm running Ubuntu 12.04. In the Vuze downloads properties, it says Owner: root. I don't know how to change that. This has only happened in Ubuntu, not Windows.
Asked
Active
Viewed 751 times
Shadoww
- 1
You were probably running Vuze as root, so all files downloaded by it are now owned by root. Make sure Vuze is closed, open a terminal and go to the folder where the files in question are located. Then run the following command:
sudo chown -cR $USER:$(id -gn $USER) .
(Please note that the point at the end is part of the command). Now start Vuze and everything should work just fine.
Donarsson
- 2,749
