I have 64 bit ubuntu 12.04 on my system. with nvidia graphic card. i installed some packages off line by using dpkg and also some programs from source code. now i have problem installing wine on my system. i have tried these commands:
sudo apt-add-repository ppa:ubuntu-wine/ppasudo apt-get updatesudo apt-get install wine1.7
but it gives me this:
wine1.7 : Depends: wine1.7-i386 (= 1:1.7.12-0ubuntu1)
i have also tried aptitude:
sudo aptitude install wine1.7
one of the solution it suggests is this :
Remove the following packages:
1) empathy
2) espeak
3) ffmpeg
4) gnome-media
5) gstreamer0.10-plugins-good
6) indicator-sound
7) libasound2-plugins
8) libav-tools
9) libavdevice53
10) libcanberra-pulse
11) libespeak1
12) libfarstream-0.1-0
13) libfluidsynth-dev
14) libfluidsynth1
15) libjack-dev
16) libjack0
17) libportaudio2
18) libpurple0
19) libtelepathy-farstream2
Install the following packages:
40) libcanberra-gstreamer [0.28-3ubuntu3 (precise)]
Keep the following packages at their current version:
63) wine1.7 [Not Installed]
64) wine1.7-amd64 [Not Installed]
65) wine1.7-i386:i386 [Not Installed]
Leave the following dependencies unresolved:
84) wine1.7-amd64 recommends libasound2-plugins
85) wine1.7-i386:i386 recommends libasound2-plugins:i386
86) wine1.7-i386:i386 recommends libsane:i386
87) wine1.7-i386:i386 recommends libxcomposite1:i386
88) wine1.7-i386:i386 recommends libxcursor1:i386
89) wine1.7-i386:i386 recommends libxi6:i386
90) wine1.7-i386:i386 recommends libxinerama1:i386
91) wine1.7-i386:i386 recommends libxrandr2:i386
92) wine1.7-i386:i386 recommends libxrender1:i386
93) wine1.7-i386:i386 recommends libxt6:i386
94) wine1.7-i386:i386 recommends libxxf86vm1:i386
as it shows aptitude is going to delete many unrelated packages and not installing wine.
i don't know how resolve this dependecy problem. i could install wine on newly installed ubuntu but in my case i don't know what packages are causing this problem. i also tried other version of wine such as wine wine1.6 wine1.4 wine1.3. i also tried installing wine from source code but it only can run non gui applications.
