I have a dual boot windows 8 and Ubuntu on my Laptop.
Is it possible to read the Windows licence key under ubuntu? (I guess it is hidden in the Windows registry somehow)
I found it here. The key seems to be stored in the ACPI-firmware:
sudo strings /sys/firmware/acpi/tables/MSDM
Which gave me the following results:
MSDMU
LENOVOCB-01
ACPI
(I replaced the product key with #)
pipe into | tail -n1 if you need only the key as output.
If your HD is broken and need to install on a new HD or just want to know the key without an HD, this may help you:
sudo acpidump > myhiddenkey.txt
after that, search in your HOME folder the .txt file you just created. Press F3 to search within the file the word "MSDM" and bingo!
If you do not have acpmdump yet, time to install it using
sudo apt-get install acpidump
It worked on my Live pendrive of Ubuntu 14.04 LTS on Positivo notebook. The key was of a Windows 8 Single-language.
A slight refinement on the accepted answer. This will only print the key:
sudo strings /sys/firmware/acpi/tables/MSDM | grep .*-.*-.*-.*-.*
