I have tried almost every comment in this subject.
my .xsession-errors file says:
openConnection: connect: No such file or directory
cannot connect to brltty at :0
and that is all. I can login as a guest but not with my account.
After some days with this issue and many SO threads read, I found that this seems to be an Ubuntu open Bug (Status 'Incomplete' as of July 2015).
More information about it here: https://bugs.launchpad.net/ubuntu/+bug/1285444
The quick solution seems to be to rename the file that stores dconf settings:
$ mv ~/.config/dconf/user{,.old}
Delete both .Xauthority and .ICEauthority from your user's home directory.
If you see old or backup or appended versions of either of these (for example .ICEauthority-c, ICEauthority, or .Xauthority.old) delete those too.
(Not having any of these files will not harm your system. They will be recreated at reboot/login.) After this, just reboot or logout & log back in and enjoy your computer again.
Tested on my system (Xubuntu 14.04 x86, linux kernel 3.13.0-35-generic)
I also have the same problem, cannot login to ubuntu 14.04, but now I have succeed to login ^_^. This problem also have happened to older Ubuntu version, where I get to know the solution. In my case there was a mismatch on desktop config from the user I login and the available desktop config. Here what i did: ([username] just as a placeholder)
First I check the lightdm.log:
sudo nano /var/log/lightdm/lightdm.log
I had a suspicion on these lines:
[+27.41s] DEBUG: Session pid=1114: User [username] authorized
[+27.42s] DEBUG: Session pid=1114: Greeter requests session ubuntu
[+27.42s] DEBUG: Seat: Failed to find session configuration ubuntu
[+27.42s] DEBUG: Seat: Can't find session 'ubuntu'
why did lightdm look for "ubuntu" session? This was because of [username] which i use its xsession is ubuntu. It was on /var/lib/AccountsService/users/[username]:
[User]
Language=en_US
FormatsLocale=id_ID.UTF-8
XSession=ubuntu <===================== THIS ONE
Background=/home/[username]/Pictures/Wallpapers/1781785_10201241375132193_1896210726_o.jpg
SystemAccount=false
[InputSource0]
xkb=us
Then i look at the xsession in folder /usr/share/xsessions. There was only gnome.desktop, no ubuntu.desktop.
So that I changed the content of /var/lib/AccountsService/users/[username]:
from XSession=ubuntu to XSession=gnome
Problem solved ^_^
I had the same problem on Ubuntu 13.04.
I rewrote the gnome.desktop entry in /usr/share/xsessions because it was missing:
[Desktop Entry]
Name=GNOME
Comment=This session logs you into GNOME
Exec=gnome-session --session=gnome
TryExec=gnome-shell
Icon=
Type=Application
X-LightDM-DesktopName=GNOME
X-Ubuntu-Gettext-Domain=gnome-session-3.0
Then I removed gnome-session-* and reinstall all. Afterwards everything worked fine and I could choose the session I wanted, unity, gnome and so on.
I had a similar issue today, I noticed that some files and directories in the users home directory were owned by root, in particular .ICEAuthority, (this was most likely as a result of me trying to setup VNC). Anyway, once I used chown to change the ownership of these files back to the user I was able to login correctly again.
I compiled Krita from source & had to modify the .profile to include the nonstandard install directory. I did it badly apparently. Once I corrected the syntax I could login as expected again!
