I could not able to dual boot ubuntu from USB. I am using windows 8.1 and the system was preinstalled with it.my model is lenovo u430p.
I disabled the secure boot option and checked it but it didn't work as it always boots windows only. Cant able to figure out even after checking the forums.So my question are:
  • Is anyone facing the same problem?
  • Can anyone elaborate on the steps and tell where I am going wrong?
Thanks in advance
Vigs
You have to do one of two things:
  • First, you must make sure you burned a bootable version of Ubuntu on a USB.
  • Second, you must set your BIOS priority to boot from USB first.
Linuxlive USB is free, easy and safe way to make a bootable USB of not just Ubuntu, but any linux distribution. Once you have made a bootbale version of your linux distribution (Ubuntu), reboot your computer and rapidly press F4 (or F11, whichever takes you to your BIOS menu) and change the boot order for your computer from (presumably) your hard drive to your USB port and it should boot up a linux liveCD in which you can use linux without installing it. If you do plan to install linux, it will also give you onscreen instructions on what to do, step-by-step to install it onto your computer.
