I'm not able to enable Wireless using the hardware switch -f12- on my HP Pavilion dv6-7080-se.
the Enable Wireless option is greyd out so I cannot enable it.
while starting ubuntu when i press f12 -which starts wifi drive- for a login time the wifi works.
The results of iwconfig for my system are as follows
eth0 no wireless extensions.
eth1 IEEE 802.11abg ESSID:off/any
Mode:Managed Access Point: Not-Associated
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:on
lo no wireless extensions.
the result of rfkill list all for my system is as follows
: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: yes
2: hp-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: yes
3: hp-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: yes
5: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
6: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: no
here is my sudo lshw -C network result.
*-network
description: Wireless interface
product: BCM4313 802.11bgn Wireless Network Adapter
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:0a:00.0
logical name: eth1
version: 01
serial: 08:ed:b9:26:06:81
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.20.155.1 (r326264) latency=0 multicast=yes wireless=IEEE 802.11abg
resources: irq:19 memory:d4500000-d4503fff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:0b:00.0
logical name: eth0
version: 07
serial: 08:2e:5f:73:2a:e2
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.1.2 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:42 ioport:2000(size=256) memory:d4404000-d4404fff memory:d4400000-d4403fff
lspci -vnn | grep Network showed:
0a:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
