-1
I tried all the possibility kindly let me know how resolve this error message and how to install git in my machine,
(personal)root@ubuntu:/home/shan/workspace/projects# apt-get -f install git-core
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 git-core : Depends: git (> 1:1.7.0.2) but it is not going to be installed
 mysql-server-5.5 : Depends: mysql-server-core-5.5 (= 5.5.35-0ubuntu0.12.04.1) but 5.5.35-0ubuntu0.12.04.2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Mitch
  • 109,787
Shanmu
first of all u need to remove some dependency which was conflit using
sudo apt-get autoremove
sudo apt-get autoclean
sudo apt-get clean
Then add the Thirdparty Repository Using
sudo apt-get install build-essential
sudo apt-get install python-software-properties
sudo add-apt-repository ppa:git-core/ppa
While adding this Press Enter
sudo apt-get update
sudo apt-get -y install git git-man git-svn
Now your git will work fine..
