I have a problem installing Ubuntu 13.10 on a Sony Vaio Pro 13. Here are the steps I followed so far (with no success in booting in 13.10):
  1. The Vaio came with Win 8 pre-installed so I created an image.
  2. I used an Ubuntu 13.10 (64bit) live USB to try ubuntu and installed it in the system wiping out win 8 in the process.
  3. I tried to boot ubuntu with no success, cannot find the operating system error message so I
  4. Used the image CDs to get win 8 back again.
Second attempt I follow step 2 above, but I try to follow the instructions in http://steffankarger.nl/2013/12/10/ubuntu-13-10-on-the-sony-vaio-pro-13/ with no success. Trying to update grub gave me an error.
Then I found this: 13.10 doesn't boot on Vaio Pro 13 So I followed the advise and ran boot repair. The output can be found here: http://paste.ubuntu.com/6949962/
I still cannot boot into ubuntu. Moreover, I cannot seem to get to bios settings (assist key will not work), neither I can run ubuntu via the live usb any more. Using the recovery image CDs doesn't work either.
Any ideas?
Kostas
  • 101
You can fully shut down the laptop by holding down the power button for 5 seconds. Then start it with the assist button. If that does not work, you can hold shift down when you click on reboot in windows. this should take you to a special menu. there you can reboot in bios (select advanced tools). in bios disable secure boot and set the boot mode to legacy (change from UEFI).
The only way I could install ubuntu was with an external optical drive (usb dvd-rom). just let it boot and don't select anything until the install/try menu appears. After this, proceed normally.
Cheers!
bogdan
  • 106
