I have Ubuntu 13.10 on my desktop.I wanted to install the "D-Link DWR-730" 3G modem drivers, but the default autoplay software for Ubuntu says "kernel not supported" for this.
I ran the dpkg -i command to install the .dep files manually, but after this every apt-get command returns an error and tells me to run apt-get -f install to correct this.
I ran apt-get -f install, but it still returns an error, and I can't install anything from apt-get. The apt-get error is as follows:
Errors were encountered while processing: flashplugin-installer E: Sub-process /usr/bin/dpkg returned an error code (1)
I ran apt-get remove flashplugin-installer, but that also returns an error.
sudo apt-get -f install gives the following output:
Reading package lists... Done Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. 1 not fully installed or removed.
Need to get 0 B/7,008 B of archives. After this operation, 0 B of additional disk space will be used.
dpkg: error processing flashplugin-installer (--configure): Package is in a very bad
inconsistent state - you should reinstall it before attempting configuration.
