I tired out the fglrx driver form Additional Drivers program and they were not what I thought it would be, so I downloaded the drivers from AMD... but when I run the program like this sudo ./amd-driver-installer-13.35.1005-x86.x86_64.run I get this:
[Error]A previous installation of fglrx driver detected to be loaded.
User must uninstall existing fglrx driver
or run install with force option.
Forcing the installation is not recommended.
I tried to remove the driver rom Additional Drivers Program again and tried to re-install... still the same message, then I did:
sudo apt-get remove --purge fglrx
Then tried the installer again. STILL the same message. What do I have to do to completely get rid of fglrx???
(P.s I did reboot after every move)
Not Amused
  • 888
  • 20
  • 38
I do the installation a bit different. You could try this:
# Add the installer script it its own directory. For example amddriver
cd amddriver
# Create deb packages for precise (12.04) or quantal (12.10)
sudo sh ./amd-driver-installer-13.35.1005-x86.x86_64.run --buildpkg Ubuntu/precise
# Force overwrite the older packages with the new ones
sudo dpkg --force-overwrite -i *.deb
This works for me for removing:
sudo apt-get remove --purge fglrx fglrx_* fglrx-amdcccle* fglrx-dev*
Evenbit GmbH
  • 4,726
