I have just got my new usb wifi dongle and I am trying to get it running on 13.10. lsusb gives me the following:
$ lsusb -v
Bus 002 Device 005: ID 148f:7601 Ralink Technology, Corp.
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x148f Ralink Technology, Corp.
idProduct 0x7601
First thing I have tried was to install the drivers from the cd that was attached to it. There I have found this file 2011_0719_RT3070_RT8070_RT3370_RT5370_RT5372_RT2070_Linux_STA_V2.5.0.3_DPO.bz2 and in the readme there was a note for
ModelName:
RT2870 Wireless Lan Linux Driver
Driver lName:
rt2870.o/rt2870.ko
After launching sudo make (sudo because I had an issue with copying to cp cannot create regular file /tftpboot' permission denied), sudo make install now I can
$ sudo modprobe rt5370sta
I also have rt2800usb but it also doesn't work.
Now when I enter the usb dongle I get in syslog
Feb 18 15:53:03 xxx kernel: [ 302.509247] usb 2-1.3: new high-speed USB device number 5 using ehci-pci
Feb 18 15:53:04 xxx kernel: [ 302.969353] usb 2-1.3: New USB device found, idVendor=148f, idProduct=7601
Feb 18 15:53:04 xxx kernel: [ 302.969359] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 18 15:53:04 xxx mtp-probe: checking bus 2, device 5: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3"
Feb 18 15:53:04 xxx mtp-probe: bus: 2, device: 5 was not an MTP device
I have also tried this http://gowthamgowtham.blogspot.com/2013/11/mediatekralink-wifi-adapter-in.html but when I enter ra0 configuration to /etc/network/interfaces then pc won't boot for more than 1-3 minutes and when it boots there's only lo interface loaded.
EDIT
The best part is that most of the link at MediaTek's website (they had a fusion apparently) is non existent http://www.mediatek.com/_en/07_downloads/01_windows.php?sn=501
EDIT2
After somehow getting my hands on 3.0.0.4 drivers for mt7601U i get the following in syslog
Feb 18 16:55:26 xxx kernel: [ 1975.959906] rtusb init rt2870 --->
Feb 18 16:55:26 xxx kernel: [ 1975.959913] Error: Driver 'rt2870' is already register
ed, aborting...
EDIT3
I somehow got this working but when I launch wpa_supplicant I get the following debug log
