I just recently started using ubuntu for things, other than the terminal. The Side menu is pretty nice, however I am using 3-4 programs (in the definition that they have an icon and appear on the side bar), so most of the space the task bar requires is not used.
Is there a way to have the icons on the top, where the clock, sound and email are? Some programs, like skype or spotify appear there. I want all programs to appear there and, if possible, to have icons by default and start the programs from there.
Is it possible ? If so, how ?
Bloodcount
  • 231
You can check if this works for you, if not, have in mind that Unity have been designed with certain guidelines. In particular, the indicators are not used for window/task management. You can set the Launcher to auto-hide and install a dock/panel and configure it to suit your needs. There are many dock/panel alternatives: docky, cairo-dock, xfce4-panel, gnome-panel, tint2, lxpanel, ....
You could also install KDE or Xfce, which can be easily configured to have a panel on the top as you wish. The packages are named kde-runtime and xfce4.
edwin
  • 3,829
