How can I configure firewall for what I use as a web development server. I should be blocking all ports except 80 (HTTP), FTP, SSH? I tried configuring using ufw, gufw, firestarter but I ended up blocking myself from surfing the net ... :)
Asked
Active
Viewed 4,717 times
JM at Work
- 2,015
Here is my ufw configuration
sudo ufw enable #Enable ufw
sudo ufw default deny #By default deny everything
sudo ufw allow 22 #Allow port 22 (ssh) I also use this for sftp
sudo ufw allow 80 #Allow port 80 (http)
sudo ufw allow 9418 #Allow port 9418 (git) You probably wont need this
sudo ufw limit ssh/tcp #Limit connections to ssh/tcp to slowdown possible attacks
LayerCake
- 1,046
