24
I'm trying to get a PHP routing library set up. They give this example for a .htaccess file:
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . index.php [L]
I couldn't get this to work, so I tried enabling mod_rewrite, but it says "Module rewrite already enabled".
Why is it not working properly? Thanks! I'm running Ubuntu Precise 12.04, and apache2.2.22. (Checked for any updates)
EDIT: A couple more details, it's a PuPHPet vagrant build, rewrite should be enabled.
5 Answers5
42
You need to allow the overwrite.
<Directory "/path/to/document/root/">
  AllowOverride All
</Directory>
Evenbit GmbH
  • 4,726
22
First of all, set your httpd configuration to this (the path may differ with one another. In my ubuntu it's placed at /etc/apache2/sites-available/default):
DocumentRoot /var/www
<Directory /var/www/>
    Options Indexes FollowSymLinks MultiViews
    AllowOverride all
    Order allow,deny
    allow from all
</Directory>
After that, you should enable mod_rewrite with this command:
sudo a2enmod rewrite
The last one, restart your apache service:
sudo service apache2 restart
To ensure that, you can check it again from phpinfo in Configuration > apache2handler > Loaded Modules there must be written mod_rewrite and it means mod_rewrite is enabled.
metamorph
  • 1,693
I had the similar problem, but the other answers did not helped me. This line at the begining of .htaccess solved my problem:
Options +FollowSymLinks -MultiViews
My problem was that I didn't have RewriteEngine on set early on in the file.
<VirtualHost *:80>
        ServerName &URL&
        ServerAlias *.&URL&
    ServerAdmin &amp;EMAIL_ADDRESS&amp;
    DocumentRoot            /var/www/&amp;URL&amp;/public
    RewriteEngine on
    # LogLevel: Control the severity of messages logged to the error_log.
    # Available values: trace8, ..., trace1, debug, info, notice, warn,
    # error, crit, alert, emerg.
    # It is also possible to configure the log level for particular modules, e.g.
    # &quot;LogLevel info ssl:warn&quot;
    LogLevel                debug
    ErrorLog                /var/www/&amp;URL&amp;/storage/logs/apache2_error.log
    TransferLog             /var/www/&amp;URL&amp;/storage/logs/apache2_transfer.log
    &lt;FilesMatch &quot;\.(cgi|html|php)$&quot;&gt;
            SSLOptions +StdEnvVars
    &lt;/FilesMatch&gt;
    # &lt;------------  Here I used to have `RewriteEngine on`
    # Handle Front Controller...
    RewriteCond %{DOCUMENT_ROOT}%{REQUEST_FILENAME} !-f
    RewriteCond %{DOCUMENT_ROOT}%{REQUEST_FILENAME} !-d
    RewriteRule ^ /index.php [L,QSA]
</VirtualHost>
I dont know why but it helped when I placed RewriteEngine on higher up.
In my case, I moved one site from a different partition to the Apache's partition, but I had to create a symlink for the old location pointing this folder. The problem was that DocumentRoot was not updated, kept pointing to the old path, that is a link now.
PS: It is NOT a comercial website, only an intranet for "domestic" use.
So MOD_REWRITE stopped working because DocumentRoot was not poiting to the new folder path, but to the link end.
[ partition A (Apache) ] <-- Folder moved  <-- [ FOLDER partition B ]
[ partition A (Apache) ] --> Symbolic link --> [ (link) partition B ]
When I updated DocumentRoot with the real folder that now is in "A", it solved the problem.
