The closest I got was umask to change the default permissions set for files/folders. However, umask doesn't seem to allow enabling the x bit for files:
The base permissions for directories are 0777 (rwxrwxrwx) and for files they are 0666 (rw-rw-rw-). Reference
I also saw this Ask Ubuntu post which makes sense, but still, umask clearly has an involvement in the issue, not just touch's code, because when I change umask, touch's results are affected).
Is there any way to create files with the execution bit set, at least for the user section (ideally -rwx-r-x-r-x = 755)
bazz
  • 171
Yes.
setfaclcommand will do what you want. See man setfacl for a complete manual.
sudo setfacl -Rdm g:groupnamehere:rwx /base/path/members/
sudo setfacl -Rm g:groupnamehere:rwx /base/path/members/
R is recursive, which means everything under that directory will have the rule applied to it. d is default, which means for all future items created under that directory, have these rules apply by default. m is needed to add/modify rules.
The first command, is for new items (hence the d), the second command, is for old/existing items under the folder. Hope this helps someone out as this stuff is a bit complicated and not very intuitive.
source
NickTux
  • 17,865
  • 57
  • 66
