I was trying to run the Windows diagnostic that ships with Sony laptops when it "froze" and I've lost my Linux 12.04 partition. I had VM's and software configured that I can't afford to lose. Please help me return to the state where I was before I tried running that Windows tool.
I am running a Lunux 13.10 LiveCD.
When I run the command: sudo gpart /dev/hda, I get the following output:
*** Fatal error: open(/dev/hda): No such file or directory.
However, when I run the command sudo fdisk -l, I get the following output:
Disk /dev/sda: 640.1 GB, 640135028736 bytes
255 heads, 63 sectors/track, 77825 cylinders, total 1250263728 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x2d85c4ea
Device Boot Start End Blocks Id System
/dev/sda1 2048 28887039 14442496 27 Hidden NTFS WinRE
/dev/sda2 28887040 29091839 102400 7 HPFS/NTFS/exFAT
/dev/sda3 29091840 1250260991 610584576 7 HPFS/NTFS/exFAT
ubuntu@ubuntu:~$ gpart /dev/hda
How should I proceed?
