I am new to Ubuntu so I'm not sure why I keep getting this every time I try to install/upgrade something. Below is just an example of the error:
W: Failed to fetch http://ppa.launchpad.net/deluge-team/ppa/ubuntu/dists/saucy/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/deluge-team/ppa/ubuntu/dists/saucy/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Any ideas?
Flyk
  • 1,480
  • 18
  • 24
sj4444
That ppa is only available for Ubuntu up to 12.10 - http://ppa.launchpad.net/deluge-team/ppa/ubuntu/dists/. As it is not supported, you might as well just remove it.
Open 'Software & Sources'
Search for it and open it in Dash
Then under the the Other Software tab, untick/remove the following: 'ppa.launchpad.net/deluge-team/ppa/ubuntu saucy main' and 'ppa.launchpad.net/deluge-team/ppa/ubuntu saucy main (Source Code)'
Exit, and press the Reload, or exit and run sudo apt-get update.
You may also be able to remove it by running:
sudo ppa-purge ppa:deluge-team/ppa
sudo apt-get update
Wilf
  • 30,732
