It would be really fast to open most used folders by an application finder or something like that. It worked quite well in windows pressing win+r and type name of a folder shortcut in System32 folder.
Is it possible to do something like that in Xubuntu too?
E.g. Win+R to open application finder (or something similar) and type "Do" to open dowloads folder?
How would you do that? Now I need to open default folder and then click to a left panel. I understand it's easier to assign a shortcut to each location but that's not managable if you have many locations. I don't really like docks neither because Cairo always got stucked and did some troubles to me...
How would you solve this problem?
Thanks in advance.
Sebastian
Sebastian
  • 1,238
On Ubuntu Saucy 13.10, Win+R does exactly what you want, it opens the Application Finder in Xbuntu (XFCE).
exo-desktop-item-edit --create-new --name='downloads' --command='thunar /root/shared/downloads' ~/.local/share/applications
A GUI will pop up to edit the item further. The item will appear in a Application submenu called 'Other'
Then simply hit Win+R -> 'item name'
to setup a lot of these, add this to your .bashrc
function launchy(){
    if [ -z "$1" ]; then
        echo "missing abs path"
        return
    fi
    exo-desktop-item-edit --create-new --name="$1" --comment="thunar $1" ~/.local/share/applications
For some reason, the --command arg is not working, so I just cut paste from comment to command in the GUI.
Usage: launchy /root/logs
win+R logs
Kevin
  • 1,031
http://launchy.net/ is amazing on Windows and also 'works' on linux (was a little buggy).
A nice hack, you 'add favourites' eg: your download folder, in Explorer window, then add 'C:\Documents and Settings\user\Favourites' to the Launchy index, then Alt+Space 'download' jumps to that folder.
The same setup can be done via symlinks on linux, although less intuitive than the 'add favorite' button.
Kevin
  • 1,031
Well, solution that actually works immediately is to use "custom actions" in Application Finder preferences.
Pattern: name_you_want_to_type
Command: pcmanfm '/home/user/folder/folder'
Works like a charm.
So you can easily "rename" applications too.
Pattern: writer
Command: /usr/bin/wps %f
(for Kingston Writer, e.g.)
Done.
Sebastian
  • 1,238
