I decided to migrate from Ubuntu 13.10 to 12.04 LTS, so I have downloaded .iso image and wrote it to my USB-stick. During the installation, on a stage of partitioning hard drive, I met one problem.
I have two big partitions (Windows partition, partition for Files) and it's all clear about them. But I also have two small partitions. The first one is FAT32, 100MiB size and in it there are Windows bootloader files, Ubuntu bootloader files. The second one is 128MiB size, unknown filesystem, "msftres" flag.
What should I do in order to correctly install Ubuntu? As I know, I should choose the first 100MiB FAT32-partition as a EFI-partition, but I am afraid that Windows bootloader files will be destroyed. Please, help me.
LiveWireBT
  • 29,597
Krosis
If there's already an efi partition, you do not need to do any thing. Just mount it to /boot/efi. Then installer should do everything for you.
For me, sda3 is \efi and sda8 is /boot, so what I need to do is
mount /dev/sda8 /boot
mkdir /boot/efi && mount /dev/sda3 /boot/efi
finally it looks like:
housezet@arch: ~
$ lsblk
NAME    MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda       8:0    0 931.5G  0 disk
├─sda1    8:1    0   260M  0 part
├─sda2    8:2    0   1.5G  0 part
├─sda3    8:3    0   260M  0 part /boot/efi
├─sda4    8:4    0   128M  0 part
├─sda5    8:5    0 845.1G  0 part /home/win
├─sda6    8:6    0   392M  0 part
├─sda7    8:7    0  33.9G  0 part
├─sda8    8:8    0   500M  0 part /boot
├─sda9    8:9    0  19.5G  0 part /
├─sda11   8:11   0    27G  0 part /home
└─sda12   8:12   0     3G  0 part [SWAP]
sr0      11:0    1  1024M  0 rom
and
housezet@arch: ~
$ ls /boot
efi  initramfs-linux.img  vmlinuz-linux
For 'msftres' flags, refer to this question: Is it safe to format msftres, msftdata and hidden partitions?
House Zet
  • 449
In 12.04 you should not choose the guided option to install along side Windows, as that will create a 2nd EFI System Partition (ESP). (To my knowledge there should only be one ESP per hard drive, but I may be wrong on that or implementations differ.)
Instead choose to manually specify the partition layout and choose to use the existing ESP that already contains the Windows bootloader files as the ESP of your Ubuntu installation. By choosing that predefined option, the partition will not be formatted (the checkbox is disabled) and Ubuntu's bootloader files should only be copied to \EFI\ubuntu\. \EFI\Boot\ and \EFI\Microsoft\ directories should be left untouched.
Backing up contents of the ESP as suggested by @RodSmith is always a good idea. If something goes wrong you could just copy the files back and if the Windows boot entry itself got deleted you could add it back with efibootmgr or bcfg via UEFI shell. But Ubuntu's installer only creates UEFI bootmenu entries, it doesn't delete any of them. You can also run bcdboot to repair a broken BCD configuration from another Windows installation or installation media.
LiveWireBT
  • 29,597
