When I use System Settings-Additional drivers- and try to activate; NVIDIA binary Xorg driver, kernal module and VDPAU library,
I get this message; SystemError:Unable to correct problems,you have held broken packages.
Is there anyway to fix this? Ubuntu 12.04 LTS
Bob
Use this answer to completely remove nvidia drivers from your system.
Then, reboot the system and when you login to your Desktop Environment, open a terminal (open the terminal with CTRL+ALT+T) and issue the following commands (one by one - copy paste them from here to your terminal).
sudo apt-get update
sudo apt-get install nvidia-173
sudo nvidia-xconfig
If above procedure goes well, without errors, then reboot once more and it should be fine.
NickTux
  • 17,865
  • 57
  • 66
