I'm using a Samsung RV509 laptop with Ubuntu 12.04 LTS.
Can anyone help me to decrease the brightness in my laptop?
kiri
  • 28,986
Karthik
  • 33
On laptops, you will often be able to adjust brightness, by pressing the FN button, and a specific F1 - F12 at the same time. Take a look at your F1 - F12 buttons. There should be small icons with a blue color on. If some of them look like they could be related to brightness, try it with the FN button. Sometimes it is also arrow keys and other buttons you will need to use.
If your keyboard looks like this, you can adjust your brightness by using the FN key and the UP and Down arrow keys. Your volume can be adjusted with FN+Arrow key Left or right, and so forth.
Good luck.
abu_bua
  • 11,313
Try using xbacklight.
  • Install it by running sudo apt-get install xbacklight in a terminal.
  • Change brightness by xbacklight -set <level>, where <level> is an integer ranging from 0 to 100 (lowest brightness to highest).
For example, to set medium brightness one would use
xbacklight -set 50
NiiL
  • 101
first know the output name
xrandr -q
for example my output name is DVI-I-2
The brightness can be changed like this:
xrandr --output DVI-I-2 --brightness 1
Maythux
  • 87,123
If the options that are built into your keyboard give you trouble, which is often the case, you can use xbacklight. If not already installed, you can install it via the terminal with:
you can then change the backlight:
xbacklight -set [percent]
where the [percent] is a value between 0 and 100, i.e.:
xbacklight -set 50
would set the backlight to 50% of the max value.
if you want keyboard shortcuts for increasing and decreasing the backlight, you could assign
xbacklight -inc 10
and
xbacklight -dec 10
to whichever keybindings you'd like, using the "keyboard" menu and the "shortcuts" tab. These would then increase the backlight by 10%, and decrease it by 10%, respectively.
Hope this helps.
