I have recently installed Ubuntu 13.10 on my DELL laptop Inspiron E1505. It seems to work okay except I have yet to be able to connect to the wifi in my home. I have googled several answers on here but none have seem to work for me.
I cannot seem to find the "System Settings -> Additional Drivers"
I am a n00b but following all the advice from posts. I have gotten this from the terminal.
john@john-MM061:~$ iwconfig
lo        no wireless extensions.
john@john-MM061:~$ sudo rfkill unblock all
[sudo] password for john:
john@john-MM061:~$ sudo modprobe rtl8192cu
john@john-MM061:~$ sudo iwlist wlan0 scan
wlan0     Interface doesn't support scanning.
john@john-MM061:~$ rfkill list all
john@john-MM061:~$ dmseg | grep iwl
No command 'dmseg' found, did you mean:
 Command 'dmesg' from package 'util-linux' (main)
 Command 'mmseg' from package 'sunpinyin-utils' (main)
dmseg: command not found
john@john-MM061:~$ dmesg | grep iwl
john@john-MM061:~$
john@john-MM061:~$
john@john-MM061:~$
john@john-MM061:~$ lspci -nnk | grep -i net -A2
03:00.0 Ethernet controller [0200]: Broadcom Corporation BCM4401-B0 100Base-TX [14e4:170c] (rev 02)
    Subsystem: Dell Inspiron 6400 [1028:01af]
03:01.0 FireWire (IEEE 1394) [0c00]: Ricoh Co Ltd R5C832 IEEE 1394 Controller [1180:0832]
0b:00.0 Network controller [0280]: Broadcom Corporation BCM4311 802.11b/g WLAN [14e4:4311] (rev 01)
    Subsystem: Dell Wireless 1390 WLAN Mini-Card [1028:0007]
    Kernel driver in use: wl
john@john-MM061:~$ rfkill unblock lan
Bogus unblock argument 'lan'.
john@john-MM061:~$ rfkill unblock wlan
john@john-MM061:~$ sudo apt- get remove bcmwl-kernel-source
sudo: apt-: command not found
john@john-MM061:~$ sudo spt-get remove bcmwl-kernel-source
sudo: spt-get: command not found
john@john-MM061:~$ lspci -k -vv | grep -A11-i wlan
grep: 11-i: invalid context length argument
john@john-MM061:~$ lspci -k -vv | grep -A11 -1 wlan
john@john-MM061:~$
If I have to connect via ethernet cable, I know to plug it in but when I did that...still nada.
:) Thanks in advance!
landroni
  • 6,011
Try install the broadcom driver and wireless tools packages:
sudo apt-get install broadcom-sta-common wireless-tools
