I don't have Chrome installed, so I'll quote "allyourcode" from this thread :
Chrome has --window-size=width,height:
code.google.com/p/chromium/issues/detail?id=27550 That thread also
claims that --window-position also exists, but it doesn't work for me.
Found someone else for whom --window-position doesn't work:
productforums.google.com/forum/#!topic/chrome/79i1oLYhK8g
Always remember to check the help or the user's manual from the applications you're running :
man google-chrome or google-chrome --help (sometimes even google-chrome -h). The answers are usually somewhere in there (I can't check myself, I repeat : I don't use Chrome).
The usual command should be the X standard --geometry=wxh+x+y but it wasn't implemented in 2012 yet. Worth the try today though.
Placement in X standards are :
+0+0 : upper left hand corner.
−0+0 : upper right hand corner.
−0−0 : lower right hand corner.
+0−0 : lower left hand corner.
So, let's say an app should be 100 pixel by 100 pixel, on the top right corner, the command would be :
applicationname --geometry=100x100-0-0
NOTE : these are options you'll need to add to the Exec= command in the .desktop file, not a specific line. You can test these in your terminal direclty.
