In Windows I can do these steps:
1. Open Notepad
2. Copy and Paste
CreateObject("SAPI.SpVoice").Speak"Hello."
3. Save it as xyz.vbs
4. Run it/Open it
It will then speak "Hello". Is there something like this in Ubuntu?
karel
  • 122,292
  • 133
  • 301
  • 332
Unbound
  • 217
There is a link which will give detailed text to speech command line tools.
http://elinux.org/RPi_Text_to_Speech_%28Speech_Synthesis%29
The first speech package I tried was Festival. It worked fine and produces a voice like a rough sounding robot.
Festival Text to Speech
Install Festival with:
sudo apt-get install festival
Try out Festival with:
echo “Just what do you think you're doing, Dave?” | festival --tts
Espeak Text to Speech Espeak is a more modern speech synthesis package than Festival. It sounds clearer but does wail a little. If you are making an alien or a RPi witch then it’s the one for you! Seriously it is a good allrounder with great customisation options.
Install Espeak with:
sudo apt-get install espeak
Test Espeak with: English female voice, emphasis on capitals (-k), speaking slowly (-s) using direct text:-
espeak -ven+f3 -k5 -s150 "I've just picked up a fault in the AE35 unit"
Seth
  • 59,332
Melc
  • 243
Install the espeak Install espeak package. Then run in a terminal
espeak -v en "Hello"
To change the voice, please refer to the manpage. An excerpt from man espeak:
   --voices[=<language code>]
          Lists  the available voices. If =<language code> is present then only
          those voices which are suitable for that language are listed.
   -v <voice name>
          Use voice file of this name from espeak-data/voices
gertvdijk
  • 69,427
