$ sudo apt-get install cgroups-lite
[sudo] password for neethu:
Reading package lists... Done
Building dependency tree
E: Unable to locate package cgroups-lite
Avinash Raj
  • 80,446
It's not cgroups-lite.it's cgroup-lite.So try to install cgroup-lite by running the below command,
sudo apt-get install cgroup-lite
How did i know?
If you face any E: Unable to locate package error while installing a package,then there may be a chance of mispelt the package name.you have to search for the packages availabe on that name by cutting down the last letters,
apt-cache search package-name
In your case i had cutdown -lite from the package name you mentiond.
$ apt-cache search cgroups
cgroup-lite - Light-weight package to set up cgroups at system boot
libpam-systemd - system and service manager - PAM module
ulatency - scriptable latency regulator using cgroups (client)
ulatencyd - scriptable latency regulator using cgroups (server)
So the correct package is cgroup-lite.
Avinash Raj
  • 80,446
