I'm using 2 monitors with Ubuntu 11.04 and can't for the life of me figure out how to move the Unity Dash/Taskbar/whatever to where I want it (the far left side of the left monitor). No matter what I do it remains on the left side of the right hand monitor. Has anyone else figured out a way to achieve this?
Asked
Active
Viewed 1,672 times
The Unity launcher only appears on the primary monitor. You can adjust the monitors in the Monitors application (available from the Dash) to reconfigure your monitors accordingly.
Nathan Haines
- 585
This can be set by adding the line to xorg.conf. Take attention to select desired monitor's section.
Section "Monitor"
Option "Primary" "true"
EndSection
I can confirm this worked for me with ATI Radeon card + manufacturer's driver: Catalyst 11.9 (Ubuntu 11.04). Maybe also applicable under different configs.
topr
- 431
I had the same problem needed to move DASH to left monitor. Opened the display app, and just disabled the right monitor, and re-enabled it.
Was enough to make dash jump to left screen.
