I have steam on a thumb drive and tried to find the installer but the location is unknown. I copied the files from Windows and I can see the files but not the installer.
Flyk
  • 1,480
  • 18
  • 24
The Windows version of Steam will not natively run on Linux. If you've copied your Steam folder to a USB stick in Windows, this will be the Windows version of Steam. This leads us to several possibilities depending on what it is you're actually trying to do:
Installing Steam on Linux without Internet connection
You will need to download the following file to a memory stick or burn it to some form of optical media:
http://media.steampowered.com/client/installer/steam.deb
This link is available by browsing to the Steam Store About Page on a PC running Linux (if you browse to it on a Windows machine you'll get a .exe file instead, which isn't natively compatible with Linux).
Once you've got this file copied to your Ubuntu machine, you can install it by running the following command:
dpkg -i steam.deb
Note: you will still need an Internet connection on this machine to actually run Steam.
Installing Steam on Linux with Internet connection
To install Steam on Ubuntu, you can simply run the following command:
sudo apt-get install steam
This will install Steam (which will then update itself on first run, and keep itself updated in future).
Running it with Wine
The third option for running Steam on Linux is to run the Windows version of Steam on Linux via Wine.
To do this, you will need to install Wine on your machine.
Once Wine is installed, you can run many .exe files simply by double clicking on them, like you would do in Windows.
If you've already copied your Steam folder from within Windows, once you've got Wine installed you can run Steam simply by running Steam.exe from within the folder you copied.
Flyk
  • 1,480
  • 18
  • 24
Hold up. You're trying to install Steam for Windows on Ubuntu?
If you just copied your Steam folder from Windows straight onto a thumb drive, you can run steam.exe in Wine and it should work. I think the bigger question lies in what exactly you think you're trying to do.
Lucio
  • 19,191
  • 32
  • 112
  • 191
ruscur
  • 1,053
