15
I am setting up a new VPS server with LEMP. The only piece missing now is the mail server. Do I need to do something special to make it secure? or it is already secured when the installation is completed?
I think the right term is hardening postfix, does it make sense?
Timmy
  • 307
There are a lot of guides online regarding the config and steps for 'hardening' postfix.
This one courtesy of http://security-24-7.com/hardening-guide-for-postfix-2-x/
Hardening guide for Postfix 2.x
Make sure the Postfix is running with non-root account:
ps aux | grep postfix | grep -v '^root'
Change permissions and ownership on the destinations below:
chmod 755 /etc/postfix
chmod 644 /etc/postfix/*.cf
chmod 755 /etc/postfix/postfix-script*
chmod 755 /var/spool/postfix
chown root:root /var/log/mail*
chmod 600 /var/log/mail*
Edit using nano or vi, the file /etc/postfix/main.cf and add make the following changes: Modify the myhostname value to correspond to the external fully qualified domain name (FQDN) of the Postfix server, for example:
myhostname = myserver.example.com
Configure network interface addresses that the Postfix service should listen on, for example:
inet_interfaces = 192.168.1.1
Configure Trusted Networks, for example:
mynetworks = 10.0.0.0/16, 192.168.1.0/24, 127.0.0.1
Configure the SMTP server to masquerade outgoing emails as coming from your DNS domain, for example:
myorigin = example.com
Configure the SMTP domain destination, for example:
mydomain = example.com
Configure to which SMTP domains to relay messages to, for example:
relay_domains = example.com
Configure SMTP Greeting Banner:
smtpd_banner = $myhostname
Limit Denial of Service Attacks:
default_process_limit = 100
smtpd_client_connection_count_limit = 10
smtpd_client_connection_rate_limit = 30
queue_minfree = 20971520
header_size_limit = 51200
message_size_limit = 10485760
smtpd_recipient_limit = 100
Restart the Postfix daemon:
service postfix restart
Kai
  • 594
