I'm installing auslogics in my laptop to run it with wine. When I try to defrag disk or flash disk, it says
unable to access the drive. try rebooting and running defragmentation again
How can I configure wine to allow this program to access hard disk or flash drive?
Olli
  • 9,129
I'd have to agree with danijelc's comment and expand on it: auslogics can't work through Wine. This sort of system utility is designed to fix Windows. Wine isn't the same thing.
  • No direct access to filesystems to defragment them (Wine abstracts everything)
  • Even if you could con it into scanning a raw disk, Auslogics probably won't understand the filesystems you try to pass it
  • Registry access will only give you access to a Wine registry which shouldn't be too bad anyway. If it is that clogged up, consider starting a clean prefix.
Oli
  • 299,380
