17
When i run docker info command on my ubuntu 13.04 with kernel 3.8.0-19-generic
i got a warning
no swap limit support
How can i solve this?
docker info
Containers: 10
Images: 37
Driver: aufs
Root Dir: /var/lib/docker/aufs
Dirs: 59
WARNING: No swap limit support
Maythux
  • 87,123
You need a couple of arguments to be passed to the Kernel at boot.
Run sudoedit /etc/default/grub in a terminal and edit the GRUB_CMDLINE_LINUX line so it looks like this:
GRUB_CMDLINE_LINUX="cgroup_enable=memory swapaccount=1"
Save and exit and then run sudo update-grub and reboot. That should be enough.
Oli
  • 299,380
