I have a webservice running inside a docker instance which was run using the following command:
sudo docker run -d -p 4040:4040 ....
My UFW rules look like this:
~ sudo ufw status
Status: active
To                         Action      From
22                         ALLOW       Anywhere
4040                       DENY        Anywhere
22                         ALLOW       Anywhere (v6)
4040                       DENY        Anywhere (v6)
When I access the box directly via its IP, I can access port 4040. Why is the ufw rule not blocking it?
Note: As part of the docker installation, I changed
DEFAULT_FORWARD_POLICY="DROP" to DEFAULT_FORWARD_POLICY="ACCEPT"
in /etc/default/ufw as per dockers instructions here (http://docs.docker.io/en/latest/installation/ubuntulinux/#docker-and-ufw)
mrwooster
  • 171
I had the same problem and resolved it by using IPTABLES instead.
Example to only allow 3306 from source ip xxx.xxx.xxx.xxx:
Adds an accept for source matching our ip to line 1 of the FORWARD chain
iptables -I FORWARD 1 -p tcp -i eth0 -s xxx.xxx.xxx.xxx --dport 3306 -j ACCEPT
Drops all other connections on the FORWARD chain for that port
iptables -I FORWARD 2 -p tcp -i eth0 --dport 3306 -j DROP
Using the line numbers (1 & 2) forces the rules to be added above the ones created by docker such as:
-A FORWARD -d 0.0.0.0/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 3306 -j ACCEPT
There is a know issue related with this. Basically, docker is configuring Iptables behind UFW.
More information:
The short possible response:
Set DEFAULT_FORWARD_POLICY="ACCEPT" in /etc/default/ufw
Set DOCKER_OPTS="--iptables=false" in /etc/default/docker
Try running the container with a specific IP.
docker run -d -p 127.0.0.1:4040:4040 ...
