I tried to install the Ubuntu SDK on my Ubuntu 13.10 Virtual machine(VMwarePlayer) by typing sudo add-apt-repository ppa:ubuntu-sdk-team/ppa && sudo apt-get update && sudo apt-get install ubuntu-sdk in the Terminal. the process gets stuck at a point and is unable to go further so terminates. The final window of the terminal says the following:
Ign http://us.archive.ubuntu.com saucy-backports/restricted Translation-en_US
Ign http://us.archive.ubuntu.com saucy-backports/universe Translation-en_US
Fetched 1,190 kB in 51s (22.9 kB/s)
Reading package lists... Done
Building dependency tree
ubuntu-sdk : Depends: qtcreator-plugin-ubuntu but it is not going to be installed
mrwhite@ubuntu:~$
what do I do?
