So I have ubuntu 12.04 installed on my pc. I have the windows 7 files on a flash drive (boot drive) and I also copied them to my desktop. Obviously I cant run the setup.exe because .exe is a windows command so how do I install windows?
How to install Windows 7 from Ubuntu without burnning a disc
If you’re running on ubuntu and want to install Windows 7 without burning a disc, you can try following steps to install Windows 7 with the iso file.
Step1:
Download grub4dos from:http://download.gna.org/grub4dos/grub4dos-0.4.4-2009-06-20.zip Decompress the grub.exe and put this file into root directory of Ubuntu partition (“/”).
Step2:
Create a 4GB ntfs partition and paste all files from Windows7 iso into this partition.(use this GUI tool:sudo apt-get install gparted ntfsprogs.launch from system->administrator menu). use this command to mount the Win7 iso(change “/path/to/your/iso”):
sudo mount /path/to/your/iso /mnt -o loop
then cope all files in /mnt and paste them into root directory of previous created ntfs partition.
Step3:
For Ubuntu 9.10 (use grub2): run:
sudo gedit /etc/grub.d/40_custom
paste following into the end:
menuentry "Grub for Dos" { insmod ntfs
set root=(hdx,y)
linux /grub.exe }
Note: here “set root=(hdx,y)” need change,my ubuntu was installed in /dev/sda11,so it
should be “set root=(hd0,11)”
then,run:
sudo update-grub
For ubuntu 9.04 and old versions(use old grub boot loader):
run:
sudo gedit /boot/grub/menu.lst
add following:
title grub4dos
root (hdx,y)
kernel /grub.exe
boot
Note:“root (hdx,y)” is different to previous one,my ubuntu partition:/dev/sda11,and here
it should be “root (hd0,10)” (without quotes).
Step4:
Reboot and there is a new entry in grub:”Grub for Dos”or”grub4dos”.Select it and press c
to access to grub>,then:
grub>find --set-root /bootmgr
grub>chainloader /bootmgr
grub>boot
Now,we get into Win7 installation guide interface.Press Shift+F10 to cmd command
line,and run following in X:/sources loation to start:
setup.exe
hope it helps
