I tried to uninstall comodo but it is showing the following errors:
anurag@ubuntu:~$ sudo apt-get --purge remove cav-linux
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
anurag@ubuntu:~$
What can I do about this?
Seth
  • 59,332
anurag
Step #1 = Boot an Ubuntu disc, and choose try without installing
Step #2 = open nautilus and open your ubuntu install, thus mounting it.
Step #3 = Open terminal and type:
"sudo mount --bind /dev /#location#/dev"
"sudo mount --bind /proc /#location#/proc"
"sudo mount --bind /sys /#location#/sys"
"sudo chroot /#location#" (don't close the terminal or you'll have to type this again)
"apt-get --purge remove cav-linux"
Step # 4 = shutdown the live cd and reboot into your Ubuntu 12.04 install.
[#location# equates to the mounted access for your ubuntu install, eg /media/ubuntu/sda1 ]
mango
