I am setting up Ubuntu and just got to the option about using LVM to partition the hard drives. My understanding is that if I do this Ubuntu will be able to treat the two drives as one. That's great, but I also want to able to distinguish between the two drives because one is a solid state and one is not. Will I still be able to have a C and D drive with LVM, i.e. can I intentionally save a file to one verses the other?
Asked
Active
Viewed 297 times
You will indeed be able to choose where the logical volumes take their physical extents from. For illustration (taken from shell history):
sudo lvcreate VG -n LogicalName --alloc cling -L 500M /dev/dev0
The above flags can also be passed to lvchange when the volume already exists. This will move data from one disk to another:
sudo pvmove -n LogicalName /dev/dev0 /dev/dev1
Also, to avoid micromanagement of which file goes on which drive, I recommend running bcache on top of LVM.
