I need to install ubuntu alongside with windows 7. But when I clicked on "Install ubuntu alongside with windows 7" there is a msg "write previous changes to disk and continue". There was two options "Go back" and "Continue". I've three drives C:,D: and one is Recovery Drive. Will it affect the other drive when I click on continue?
I suggest you go with manual configuration of the partitions. Make an ext4 and a swap and install Ubuntu on the ext4 partition. GRUB will be installed on the MBR and it will prompt you to choose between Ubuntu or Windows.
