I wanted to follow this guide to avoid typing a password every time I want to use "sudo iwconfig" command
http://ubuntuforums.org/showthread.php?t=1132821
I tried the steps with "apt-get" command and it worked
sudo select-editor
sudo visudo
add %admin ALL=(ALL)NOPASSWD:/usr/bin/apt-get to the bottom line
but they didn't work with "iwconfig"
I believe the reason behind that is "iwconfig" source files are not stored in "/usr/bin/" directory because ls /usr/bin/ | less doesn't show anything named iwconfig
So, what is the directory I should enter before iwconfig?
Thanks in advance
loo3y35
  • 511
Running iwconfig without password
Create a file called iwconfig in /etc/sudoers.d/:
$ sudo visudo -f /etc/sudoers.d/iwconfig
Add the following:
your-user-name ALL=(root) NOPASSWD: /sbin/iwconfig
Check if the file has the right permissions:
$ ls -l /etc/sudoers.d/iwconfig
Should be:
-r--r----- 1 root root 0 Feb 1 21:34 /etc/sudoers.d/iwconfig
If not:
$ pkexec chown root:root /etc/sudoers.d/iwconfig
$ pkexec chmod 0440 /etc/sudoers.d/iwconfig
If you cannot open the iwconfig file, try:
pkexec visudo -f /etc/sudoers.d/iwconfig
-- Regards
@see:
suqed
  • 111
I could solve the problem using the following
sudo visudo
adding %admin ALL=(ALL)NOPASSWD:/sbin/iwconfig to the bottom line
loo3y35
  • 511
