After trying to install Acroread I did try to to remove it, with no success,
the message follows. Please help me because the software center was disabled as the result
sudo apt-get remove acroread
Reading package lists... Done
Building dependency tree
Virtual packages like 'acroread' can't be removed
You might want to run 'apt-get -f install' to correct these:
acroread-bin:i386 : Depends: libfontconfig1:i386 (>= 2.9.0) but 2.8.0-3ubuntu9.1 is to be installed
Depends: libxml2:i386 (>= 2.6.27) but it is not going to be installed
Depends: libxt6:i386 but it is not going to be installed
google-chrome-stable:i386 : Depends: xdg-utils:i386 (>= 1.0.2) but it is not installable
libxml2 : Depends: liblzma5 (>= 5.1.1alpha+20120614) but 5.1.1alpha+20110809-3 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
