I would like to use m23 to maintain a cluster of other Ubuntu machines, but unfortunately I can't find any documentation how to install m23 server on an Ubuntu machine. Neither are there any packages for Ubuntu.
Does anybody know how to install m23 on an Ubuntu machine?
UPDATE: The Debian source does not work for Ubuntu
 m23 : Depends: apache-common ist aber nicht but is not going to be installed
                      apache2.2-common ist but is not going to be installed
That is strange, because of the fact that apache is installed. What ever, trying to install the package leads to an error:
Package 'apache-common' has no installation candidate
I think, the problem is, that the packages in Ubuntu have a different name. Is that possible?
user5950
  • 6,406
m23 is not intended for use on Ubuntu as m23 server. There are too many dependencies on Debian system things for it to run on a derivate of Debian, which differs in crucial parts from Debian (like Ubuntu).
You would have to re-write m23 in some parts to make it run on a Ubuntu machine.
For this reason, the m23 packages won't install on Ubuntu. m23 even checks if the machine you plan to install it on is a Debian machine, and it won't start if it is on Ubuntu.
You can, however, install m23 in a VM on your Ubuntu machine. Or you can set up a Debian server for m23. You could even install m23 on a Raspberry Pi, or in a CloudStack environment. But always on Debian.
And of course, you can manage Ubuntu machines using your m23 server.
If you have questions, you can also always ask in the m23 forum - I guess questions about m23 might be answered faster and more complete there by the people who write m23 (like me, I found your question by accident).
Maren
  • 76
I found this on the m23 website for installing it in Debian.
The packages are stored on the SourceForge server and can be installed via APT. The following steps must be done as root:
Import the GPG key with
wget -T1 -t1 -q http://m23.sourceforge.net/m23-Sign-Key.asc -O - | apt-key add -
to ensure the integrity of the m23 packages.
Add
deb http://kent.dl.sourceforge.net/project/m23/m23inst ./
in the /etc/apt/sources.list file.
Run apt-get update
And install m23 with
apt-get install m23
Let all software get configured automatically ("yes"), beside you are really knowing what you are doing.
Make sure that the network interface (eth0, eth1, ...), that will be used for communication between your m23 server and the m23 clients, is the first in the list of the interfaces shown in /etc/network/interfaces and has a static IP address. This is required to ensure correct communication.
Rinzwind
  • 309,379
