I am attempting to get a display resolution of 2560x1440 to operate correctly through DVI output on my Lenovo ThinkCentre M71e running Ubuntu 12.04. The computer has both VGA and DVI connectors.
When I use the VGA connector I get the full 2560x1440 resolution of my monitor just fine. Infact this is autodetected as the default resolution with no config on my part. The only issue is some ghosting in the image due to the analog connection.
The output of xrandr at this point is as follows:
% xrandr
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 8192 x 8192
VGA1 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 60.0*+
1920x1080 60.0
1680x1050 74.9
1280x1024 75.0 60.0
1440x900 59.9
1152x864 75.0
1280x720 60.0
1024x768 75.1 60.0
800x600 72.2 75.0 60.3 56.2
640x480 75.0 60.0
720x400 70.1
HDMI1 disconnected (normal left inverted right x axis y axis)
DP1 disconnected (normal left inverted right x axis y axis)
Note that X believes the computer has VGA, HDMI, and DP (DisplayPort?) connections. It infact has VGA and DVI.
When I use the DVI connector I get only 1680x1050 resolution, and xrandr reports the following:
% xrandr
Screen 0: minimum 320 x 200, current 1680 x 1050, maximum 8192 x 8192
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 connected 1680x1050+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
1680x1050 60.0*
1280x1024 75.0 60.0
1440x900 59.9
1152x864 75.0
1280x720 60.0
1024x768 75.1 60.0
640x480 75.0 60.0
720x400 70.1
Note it believes to be connected over HDMI, not DVI.
I can try to force the correct resolution over DVI as shown below, but this simply results in a blank display.
% gtf 2560 1440 60.0
# 2560x1440 @ 60.00 Hz (GTF) hsync: 89.40 kHz; pclk: 311.83 MHz
Modeline "2560x1440_60.00" 311.83 2560 2744 3024 3488 1440 1441 1444 1490 -HSync +Vsync
% xrandr --newmode "2560x1440_60.00" 311.83 2560 2744 3024 3488 1440 1441 1444 1490 -HSync +Vsync
% xrandr --addmode HDMI1 2560x1440_60.00
% xrandr --output HDMI1 --mode 2560x1440_60.00
Notes:
- The computer has an Intel Core i5-2400 CPU with integrated graphics "Intel HD Graphics 2000".
- The DVI cable is a dual-link DVI cable that came with the monitor, so I believe it should support the 2560x1440 resolution.
- The monitor is a DGM IPS-2701WPH (http://www.scan.co.uk/products/27-dgm-ips-2701wph-pro-led-ips-monitor-hdmi-displayport-dvi-dvi-vga-2560x1440-350cd-m2-80k1-6ms-vesa)
I have also tried using cvt instead of gtf to generate the new modeline. This results in a much lower pixel clock of 241.5MHz (matches exactly the maximum pixel clock value from display manual). Unfortunately the screen still turns blank when I try this.
% cvt -r 2560 1440
# 2560x1440 59.95 Hz (CVT 3.69M9-R) hsync: 88.79 kHz; pclk: 241.50 MHz
Modeline "2560x1440R" 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync
% xrandr --newmode "2560x1440R" 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync
% xrandr --addmode HDMI1 2560x1440R
% xrandr --output HDMI1 --mode 2560x1440R
