While trying to install Code::Blocks, I run sudo apt-get install libwxgtk2.8-dev, but then receive an error listing many "unmet dependencies" for several packages.
The full list of errors:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
codeblocks:i386 : Depends: libatk1.0-0:i386 (>= 1.12.4) but it is not going to be installed
Depends: libc6:i386 (>= 2.4) but it is not going to be installed
Depends: libcairo2:i386 (>= 1.2.4) but it is not going to be installed
Depends: libfontconfig1:i386 (>= 2.9.0) but it is not going to be installed
Depends: libfreetype6:i386 (>= 2.2.1) but it is not going to be installed
Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed
Depends: libgdk-pixbuf2.0-0:i386 (>= 2.22.0) but it is not going to be installed
Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
Depends: libgtk2.0-0:i386 (>= 2.8.0) but it is not going to be installed
Depends: libpango1.0-0:i386 (>= 1.14.0) but it is not going to be installed
Depends: libstdc++6:i386 (>= 4.6) but it is not going to be installed
Depends: libwxbase2.8-0:i386 (>= 2.8.12.1) but it is not going to be installed
Depends: libwxgtk2.8-0:i386 (>= 2.8.12.1) but it is not going to be installed
Depends: codeblocks-common:i386 (= 13.12-1) but it is not installable
Recommends: gcc:i386 but it is not going to be installed or
g++:i386 but it is not going to be installed
Recommends: gdb:i386 but it is not going to be installed
codeblocks-contrib:i386 : Depends: libatk1.0-0:i386 (>= 1.12.4) but it is not going to be installed
Depends: libbz2-1.0:i386 but it is not going to be installed
Depends: libgamin0:i386 but it is not going to be installed
Depends: libhunspell-1.3-0:i386 but it is not going to be installed
Depends: libx11-6:i386 but it is not going to be installed
Depends: zlib1g:i386 (>= 1:1.2.3.3) but it is not going to be installed
Depends: codeblocks-contrib-common:i386 (= 13.12-1) but it is not installable
Recommends: valgrind:i386 but it is not going to be installed
Recommends: cppcheck:i386 but it is not going to be installed
Recommends: cscope:i386 but it is not going to be installed
Recommends: cccc:i386 but it is not going to be installed
codeblocks-dev:i386 : Depends: codeblocks-headers:i386 (= 13.12-1) but it is not installable
codeblocks-headers : Depends: codeblocks-dev (>= 13.12-1) but it is not going to be installed
Depends: codeblocks-dev (< 13.12-1.1~) but it is not going to be installed
codeblocks-libwxcontrib0:i386 : Depends: libc6:i386 (>= 2.3.6-6~) but it is not going to be installed
Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed
Depends: binutils:i386 (>= 2.14.90.0.7) but it is not going to be installed
codeblocks-wxcontrib-headers : Depends: codeblocks-wxcontrib-dev (>= 13.12-1) but it is not installable
Depends: codeblocks-wxcontrib-dev (< 13.12-1.1~) but it is not installable
libcodeblocks0:i386 : Depends: libc6:i386 (>= 2.11) but it is not going to be installed
libwxgtk2.8-dev : Depends: wx-common but it is not going to be installed
Depends: wx2.8-headers (= 2.8.12.1-14ubuntu1.1) but it is not going to be installed
Depends: libwxgtk2.8-0 (= 2.8.12.1-14ubuntu1.1) but it is not going to be installed
Depends: libwxbase2.8-dev (= 2.8.12.1-14ubuntu1.1) but it is not going to be installed
libwxsmithlib0:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
wxsmith-headers : Depends: wxsmith-dev (>= 13.12-1) but it is not installable
Depends: wxsmith-dev (< 13.12-1.1~) but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I get these errors for every single package and it happens after I try to get build essentials.
EDIT: After continuing to toil, there are still 2 dependencies that nothing can fix.
- libgcc1 (>=1:4.1.1) but 1:4.8.1-10ubuntu9 is to be installed
- codeblocks-common(=12.11-3) but 13.12-1 is to be installed
I tried re-installing. Auto remove didn't work.
EDIT: I tried -f install again to post my results. Here is what I get:
somepackages
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 240 not upgraded.
I still can't install the final two dependencies for Code::Blocks.
