I am trying to configure the ports in Redis database. I have changed the port number to 7778 in the redis.conf file. This file is in /etc/redis.conf
and I'm using this command
redis-server /etc/redis.conf
And this goes through. I'm able to get through. However if I execute this command
redis-cli
or
redis-cli /etc/redis.conf
I'm getting this error
could not connect to redis at 127.0.0.1:6379:connection refused.
I then tried this command
redis-cli -p 7778
127.0.0.1> ping
(error) NOAUTH authentication required
Braiam
  • 69,112
  1. 127.0.0.1> AUTH your password
  2. OK <--response from redis
  3. (7.75s) <--- it's too.
  4. 127.0.0.1>ping <--test if you want
  5. PONG <--you can receive response from redis
  6. you can use AUTH keyword :) and after write your password.
I have had the same problem because I changed the bind IP address in /etc/redis.conf
So I manually set the host ip by using this command:
redis-cli -h 192.168.1.100 -p 7778
Then it started working for me.
Fabby
  • 35,017
Maxter
redis-cli -p 7778
127.0.0.1> ping
Port is working. But you need enter password:
>auth <yourpassword>
OR
redis-cli -p 7778 -a <yourpassword>
OR remove requirepass in /etc/redis.conf
slava
  • 4,085
