Just tried installing Ubuntu for a class, but during installation it could not detect my Windows 8 operating system. It has a few options on what to do but I don't want to ruin my new computer. Please help.
Asked
Active
Viewed 65 times
Do this:
- Select "Something else
- Create a new partition. Format: ext2, ext3 or ext4 (preferably ext4) Mount point: / Size: Whatever you want, should be more than 20GB
- Make another partition. Format: swap Size: A bit more than the amount of ram you have eg. 16 GB ram, 20 GB swap 4: One more partition. Type: Reserved BIOS boot Size: 2 MB
- Click the ext partition.
You should be able to safely install. This is what I had to do. Just a note: GRUB may not detect Windows. A run of Boot Repair (google it) should solve it. I'll reply back when I test it.
JjStAr
- 1
Ubuntu installer, by default, recognizes both Windows 8 and Windows 8.1.
If Windows is not being recognized by Ubuntu Installer, this means that it probably won't auto-configure Windows 8 into GRUB. You can try the following, but there's still a chance that this might break your Windows bootloader and you'll have to reinstall it (See last).
It's always wise to back up (Windows). Now that you've been warned,
- Instead of default installation, use custom partitions. See this.
- Try booting up. If
GRUBgetsWindows, you're good. Otherwise, do step 3. - Follow this to manually configure
GRUBto give you the option for dual boot.
If the above didn't work, you can reset to Windows-only, see this.
Hope this helps.
